IR-ADV 6255
  • muthuk7
    • Aug 2010
    • 57
    [Jamming] IR-ADV 6255
    Dear Friends,
    Please assist me on below issue .
    one of my customer has 3 IR ADV 6255 mfd and one machine is giving intermediate paper jam . This same machine is working perfectly fine with 80 gsm A4 paper and the issues have been identified on 100 gsm coated paper.
    The same media ( 100 gsm coated ) is perfectly working with other two machines . The jam and error reports says 00 0108 jam error and as per the manual its pointed to DUPLEX MERGING SENSOR delay .
    My team tried to cleaned the sensor and swapped it from another working machine . as still the problem persist .
    Kindly advise the way forward and help us to come over from this issue
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: IR-ADV 6255
    Jam 108
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • Canuck
      Tech Specialist
      • 1713
      Re: IR-ADV 6255
      What tray? You cannot run coated paper from the decks or cassettes on this machine...try to register coated paper in a tray....ok is grayed out. Tell customer to use machine according to specs.....only source for coated is bypass. And YOU CANNOT AUTO DUPLEX COATED on this machine. If they are registering as non coated, its incorrect. Educate your customer
      • canon-korea-incheon
        • Apr 2019
        • 5
        Re: IR-ADV 6255
        Print the 3rd and 4th cassette in the A4R direction.
        Please understand that I am not good at English because I am Korean.
        • muthuk7
          • Aug 2010
          • 57
          Re: IR-ADV 6255
          hi experts
          thanks a lot for your assistance and advise .
          i will try the possibilities and keep you posted
          best regards
          • Etech50
            • Oct 2017
            • 25
            Re: IR-ADV 6255
            The 0108 jams seems to be only from the left deck. I would first look at the deflector that in under the fixing/feeder assembly. If you slide this out and look underneath, you will see it in the center. It has mylar sheets that could be damaged or the deflector is stuck. You are lucky to have 2 other machines to swaps parts as the left deck pickup unit may need replacing.
