Poor Quality Copies- IR5045 Adanvce
  • Andyboachie
    • 185
    Hello,
    I'm working on an IR5045 Advance with a disturbing copy output. It was initially giving this output, so I cleaned the inner parts and replaced the Cyan and Magenta developer and toners with perfectly working ones. But as can be seen from the numbered areas, it gives poor output.
    1. The Cyan copy appears cloudy and poor
    2. There are Cyan streaks at the edges
    3. There is a Magenta streak at the edge
    Beside these, there are Cyan drops on the copy. But as I said, the toners and developers are from perfectly working machines.
    I appreciate your time and effort and hope your suggestions help me out. Thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5019
    Re: Poor Quality Copies- IR5045 Adanvce
    Can you attach a PG-10 service test instead of this samples please?
    • Andyboachie
      • 185
      Hi,
      Ok, just that I'm a bit far from the location. I will be on my way in the next hour. Thanks.
      • zoraldinho
        • Mar 2008
        • 5019
        From this samples i see bad cian and magenta drum.Other issues can be from itb cleaner.
        • Andyboachie
          • 185
          I suspected the ITB cleaner, so presently, I already have a new one on the way. I think I will get the other clue clearer after the cleaner replacement. So good to have you!
          • canon-korea-incheon
            • Apr 2019
            • 5
            Paper may be on top of the ITB belt.
            • Andyboachie
              • 185
              Hi,
              I had to make a complete overhaul. Because user had left the machine to sit for over a year. Changed ITB blade and all drums and it did the trick. Thanks for the input buddies!
              • zoraldinho
                • Mar 2008
                • 5019
                I'm glad I can help
