Scan to folder not functioning
  • muthuk7
    • Aug 2010
    • 57
    Dear Team,
    Kindly guide me to configure SCAN to folder . In my customer premises they do have 2 different networks . xxx.xxx.180.xxx & xxx.xxx.179.xxx within one domain.
    IR-ADV C255 its perfectly working in xxx.xxx.180.xxx ( because the destination folder also in same range ) whereas it is not working in xxx.xxx.179.xxx ( because the destination folder is in xxx.xxx.180.xxx range)
    Request you help me or share your experience if you have come across
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: Scan to folder not functioning
    Folders on different network copier will not reach with SMB protocol.
    • muthuk7
      • Aug 2010
      • 57
      Hi ,
      Thanks s lot for your reply . is there any way to connect the folder which is in the same domain but different network
      • zoraldinho
        • Mar 2008
        • 5017
        FTP or scan to email.
        • DFM914
          • Jun 2010
          • 73
          Is there any chance the 2nd network has wireless? On the C256, you can run both wired and wireless protocols at the same time thus in theory, seeing 2 different networks.
          • General Copiers
            • Feb 2020
            • 27
            Hi, I'm not a Canon technician but Ricoh. With our machines you can install a second network interface to solve this problem.
            Maybe also with Canon devices...
