machine not printing
  • Reeves
    • Apr 2012
    • 296
    [Misc] machine not printing
    hi i have a canon ir3025 which is photo coping and scanning r okay but when it comes to printing its not printing i have tried to use UFR II,PCL and PS driver they are all not working i have tried with USB and crossover cable when i print a job the machine ll beep as if it want to print but it wont print if i check in log on the machine am able to see the print job in status as NG and error #853 but if i open the machine in web page its opening and am able to print a configuration page but normal printing i cant print what could be the problem
  • darkocg88
    • Jan 2018
    • 63
    Re: machine not printing
    Printer properties - driver, make sure it's set to UFR II. If it's windows 10 it tends to pull generic driver initially.
    Sent from my Moto E (4) Plus using Tapatalk
    • darkocg88
      • Jan 2018
      • 63
      Also if it's set to UFR II, reset main controller via service mode, then try again.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5017
        imageRUNNER 3025 supports advanced digital copying, network scanning and Mail Box features as standard, and optional network printing.
        Model iR3025N comes "network-ready"
        • Reeves
          • Apr 2012
          • 296
          am using windows 7
          • Reeves
            • Apr 2012
            • 296
            How do i reset the main controller in service mode
            • guitar9199
              • Sep 2016
              • 1100
              If you're using the UFR II drivers, check a couple of things.
              First... make sure you are NOT using a "WSD" printer port. Canons should always be using a Standard TCP/IP printer port.
              Second.... Go into your "Ports" tab in Devices and Printers> iR3025> Printer Properties, click on "Configure Ports" and make sure "SNMP Status" is UN-checked! I've seen this cause similar connectivity issues for a long time.
              Start simple....work your way in.
              • zoraldinho
                • Mar 2008
                • 5017
                Any updates?
                • hidius
                  • Jun 2015
                  • 128
                  #853
                  Cause 1 The job could not be executed when you tried to print a large number of pages on the printer, due to insufficient resources.
                  Remedy Reduce the number of pages to print, or execute the job again when there are no other reserved print jobs.
                  Cause 2 When sending print data to the machine from a computer, the job could not be executed because it was canceled from the printer driver.
                  Remedy Perform the operation again.
                  Cause 3 The spool region for the received data became full and all the data from the host could not be spooled with [Use Spool Function] set to 'On' in [Network Settings] in [Preferences] (Settings/Registration).
                  Remedy Set [Use Spool Function] to 'Off' in [Network Settings] in [Preferences] (Settings/Registration), and perform the operation again.
                  Cause 4 The maximum received data size was exceeded when processing the received data.
                  Remedy Perform printing again when all the jobs are complete. If you still cannot perform printing, check the sent data.
