IRC2880 touch panel calibration change
  • stefkpl
    • Sep 2017
    • 22
    [Misc] IRC2880 touch panel calibration change
    Re: IRC2880 touch panel calibration change
    have you tried pulling the op panel make sure connections are good both ends of the harness?
    do you have a like panel to swap with?
    have you updated firmware?
    really need to know other than cali's what's been done!
    Phil B. " The Dentist"
    • stefkpl
      • Sep 2017
      • 22
      Informations sur la version
      112 : Total (Noir/Grand format) 2431
      113 : Total (Noir/Petit format) 46743
      122 : Total (Quadrichromie + Monochrome/Grand format) 1059
      123 : Total (Quadri + Monochrome/Petit format) 16061
      501 : Lecture (Total 1) 28187
      301 : Impression (Total 1) 43258
      • Scottb
        • Apr 2013
        • 303
        I would try this
        FK2-0329-000 1 ANALOG TOUCH PANEL UNIT
        • guitar9199
          • Sep 2016
          • 1099
          First things first.... I'd make sure there is no dust/debris buildup around the edges of the touch panel. That can cause issues.
          Second, make sure the copier's network connection is NOT running "Power Over Ethernet"!! This will burn out network cards and control panel CPU's. I've been there....trust me on this!!
          After that, reseat all your connections and try calibrating it again. If calibration fails or doesn't hold... THEN replace the touch panel.
          • stefkpl
            • Sep 2017
            • 22
