Canon ir 2525 very light copies and prints
  • T911
    • Jun 2007
    • 628
    went with developer unit and drum but not the problem, I think it may be a transfer problem with this one. I can't see any contacts or springs missing. Is there something that may pop off or come out of place in the transfer roller area from a jam. Thanks for any help.
  • T911
    • Jun 2007
    • 628
    Re: Canon ir 2525 very light copies and prints
    btw here is a sample copy attached.
    • guitar9199
      • Sep 2016
      • 1099
      Look inside the right door, toward the front of the machine on the registration roller. There should be a flat leaf spring making contact with both the roller and the frame. Make sure it's making GOOD contact with the roller and the frame. I've seen this series do weird things when the spring is dirty or missing.
      Good luck.
      • darkocg88
        • Jan 2018
        • 63
        Try toner unit. Looks like wet toner inside.
        Sent from my Moto E (4) Plus using Tapatalk
        • T911
          • Jun 2007
          • 628
          dev unit would be clumpy on the mag roller if the toner was wet right
          • darkocg88
            • Jan 2018
            • 63
            Depends really. Vacuum the toner inside, then use different toner.
            • darkocg88
              • Jan 2018
              • 63
              When you open it you'll know
