IR5045 Advance Patch Sensor
  • Andyboachie
    • 185
    Hello,
    I would want to work on the Patch sensor for IR5045 Advance. But I find it difficult to get an image of the location. Can anyone be of help? Thanks in advance.
    • 22808
    Re: IR5045 Advance Patch Sensor
    Originally posted by Andyboachie
    Hello,
    on ANY color machine i have ever worked on....
    they are on or in frame near the itb.
    and you cannot find it in the IPB diagrams ?
    • Canuck
      Tech Specialist
      • 1713
      Under the right end of the ITB..solenoid is right there for shutter
      • Andyboachie
        • 185
        Thanks so much guys for your input!
        I found it and worked on it finally. However after, I'm having trouble with the Magenta toner/developing units. As the machine started working normal, it suddenly showed E020-0291. I had to remove the drum assembly to discover continuous toner leak. I checked and found the developer unit to be working fine. I even replaced it to see the same result (toner leak). it continues until E20-2B1 (small amount of toner in developing assembly) showed. I would like to get to the exact culprit causing the toner leak.
        Is someone familiar with this particular situation. Looking forward to to appreciate your kind suggestions.
