IR-ADV C5240I ADF not sensing
  • muthuk7
    • Aug 2010
    • 57
    [Misc] IR-ADV C5240I ADF not sensing
    Hi Experts,
    My team facing an issue with IR-ADV C 5240I . The document feeder is not sensing AR4 ( short edge feed ) . When the paper kept in A4R direction it always sense A3 .
    They have swapped the original detect sensor and system software also upgraded .
    Request you to share your experience if you have come across and your advise on this regards would be highly appreciable
  • hidius
    • Jun 2015
    • 128
    Re: IR-ADV C5240I ADF not sensing
    the reason its detecting A3 is because the A3 detector arm is being triggered. check if the arm is not broken or has been dislodged. if thats fine then check and clean the photo sensor for that arm
