Scanning Issue Image runner 8095
  • Arcadian
    • Feb 2010
    • 218
    Greetings fellow TECHIES!!!!
    i am Having issue with a canon
    Seems it not scanning
    original copy
    scanned
    for some odd reason its not scanning, could it be a setting, it doesnt do this all the time. sporadically.
    thanks for any suggestions.. Appreciated!!!
    Arcadian
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Scanning Issue Image runner 8095
    As you can see, scan is much brighter than a copy.
    Canon digital scanners have a problem with scanning stamps and various pens. Try changing the scan settings from "text + photo" to "text" and intensity. (Dark)
    • teckat
      • 16083
      original copy
      [ATTACH=CONFIG]42530[/ATTACH]
      scanned
      [ATTACH=CONFIG]42531[/ATTACH]
      Arcadian
      is original a "digital signature"
      • Arcadian
        • Feb 2010
        • 218
        no from a printed original, after scanning the image disappeared
        i do notice the dots on the scanned copied. so will up the dpi setting might be just to low.
        thanks for reply
        • teckat
          • 16083
          thanks for reply
          was original document transferred from a Word Doc to a Pdf
          so original document was physical signed ( and not digitally signed )
          • Arcadian
            • Feb 2010
            • 218
            Yes it was physically sign, then scanned.
            I will try to up the dpi and see if that help have not gone yet.
            • teckat
              • 16083
              is issue on all signed documents
              take a pen and write your name on a blank paper a few times> now scan it > and print out copies
