Error code e000025-03c0 in ImageRunner c5035
  • Wilson101
    • May 2019
    • 7
    [Error Code] Error code e000025-03c0 in ImageRunner c5035
    I replaced the tonner for cyan and after some few prints, this error code e000025-03c0 appeared. I believe it has to do with the tonner container or something. Any help?
    Re: Error code e000025-03c0 in ImageRunner c5035
    Originally posted by Wilson101
    I replaced the tonner for cyan and after some few prints, this error code e000025-03c0 appeared. I believe it has to do with the toner container or something. Any help?
    E025-04C0
    error will come up when the copier does not recognize when the small toner door (one for each color) is open or closed on toner replacement.
    Check the Black Toner Container Inner Cover Sensor PS16 in I/O P024 Bit 11 in service mode.
    not EXACT code but a place to start
    • hidius
      • Jun 2015
      • 128
      it didn't detect that the cyan toner had opened. you'll have to clear the error code in service mode to continue
