0111 jam on full coverage on iRA8295
  • V-P
    • Apr 2011
    • 679
    [Jamming] 0111 jam on full coverage on iRA8295
    I am getting a jam 0111 when the sheet is full of toner.
    When the coverage is normal - everything is fine.
    SO it happens only when full coverage on PS52 (as you can see in photos).
    I have replaced the ETB Kit also Primary Corona Assy. I checked all fingers on fuser exit and cleaned the sensors.
    Ideas? .....
    Thnx in advanceWhatsApp Image 2019-05-10 at 2.18.48 PM.jpgWhatsApp Image 2019-05-10 at 2.18.48 PM(1).jpg
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: 0111 jam on full coverage on iRA8295
    Hi E
    Sounds like fuser temp issue. Did you try with different paper settings?
    To eliminate problem try to change the setting from Quality Priority to Productivity Priority . (User Mode > Function Settings > Common > Print Settings > Thin / Plain Paper Printing Priority >Productivity Priority)
    PS51 and PS52 are only for detect paper wrapping and stationary jams.This is call Paper Anti-wrapping Control.
    when the sensor detects that the paper begins to wrap the machine stops.
    Control description
    In the case of delay jam at the fixing outlet, the DC Controller determines paper wrapping if
    the paper remains in the Fixing Assembly and executes the following.
    The brake is applied to the Fixing Motor to immediately stop operation of the Fixing Motor (to
    minimize the paper wrapping level)
    Power distribution to the coil is stopped (to ensure safety).
    A jam is displayed.(Jam Code:0111)
    Cleaning of the Fixing Roller is executed (5 times of web cleaning)
    Also you have many other options:
    COPIER> OPTION> IMG-FX> FIX-TEMP
    0 : Fixing priority, 1: Normal, 2: Productivity priority
    Set fixing/productivity: Plain paper A3+
    COPIER> OPTION> IMG-FX>FIX-TMP2
    Set fixing/productivity: Spcl ppr A3+
    COPIER> OPTION> IMG-FX>FIX-TMP3
    Set Img Quality Priority level:user mode
    COPIER> OPTION> IMG-FX>FX-IMGLV
    • V-P
      • Apr 2011
      • 679
      Hi Z,
      Long time - no talk
      It was already on productivity mode but following your advice, I have lowered the temp on fuser.
      Will see how it behaves now...
      Thnx,
      V-P
