Canon ImageRunner Advance C5051
  • Reed
    • Feb 2011
    • 261
    e Went out on a Canon ImageRunner Advance And when I tried to get into the service mode, there is a Password that must be entered by a tech. I have never seen this before. I was told by Hytec that I need to get the Firmware and reload it. Then do a couple other things. I was wondering if anyone has come across this and how can I remove the Password to enter the service mode. If I need the firmware can someone help me get it. Thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5019
    Re: Canon ImageRunner Advance C5051
    Someone make a password for a reason. You do not need a service mode for system upgrade.
    • Reed
      • Feb 2011
      • 261
      Yes I realize I don't need to go into service mode to update f/w. Also the client does not want to use the Canon Dealer in town as they have had bad experiences with them. I also realize the p/w lock was put there for a reason. I would like to disable it so I can access the service mode in the future.
      • alex@wocltd.com
        • 430
        you need sst, and then can reset password- or just overwrite hdd with f/w either way you need sst
        • 20 year tech
          • May 2014
          • 577
          Load the firmware for the device on a USB drive and plug the drive into the machine while it is off, boot into safe mode (hold down 2 and 8 while turning on the power) you should get a menu, choose the clear option (usually 4) and there will be an option to clear service mode password.
          • dan7777
            • Dec 2012
            • 680
            Try going into service mode to clear and clear password. Default is 7654321, 7654321. Then it will ask you to change it. There is a way to go to settings and change it but you need a password .
            • Reed
              • Feb 2011
              • 261
              Thanks .. 20 year tech. I will try that . That is pretty much what Hytec said.... btw.. I sent you a pm
