Canon IR Adv 8105 error 067-0001
  • Kyaw Thu Ko
    • Jun 2018
    • 10
    [Error Code] Canon IR Adv 8105 error 067-0001
    Dear All,
    Please help me.
    My IRA 8105 shows Error 0067 when printing.
    When I change the Developer, the error disappears.
    But when I put that Developer to another 8095 machine, the error shows again in 8095.
    So I think that Developer have a problem.
    So how can I fix that developer?
    Thanks in advance.
  • hidius
    • Jun 2015
    • 128
    Re: Canon IR Adv 8105 error 067-0001
    buy a new one
    • guitar9199
      • Sep 2016
      • 1100
      E067 -0001 -05 Title Developing high voltage output leak error
      Detection description
      The leak detection signal was detected 5 times in a row for
      every 20 msec.
      Remedy
      1. Check the connection between the Main Driver PCB (PCB2) and the High Voltage Unit. Main Driver side: J112, High Voltage Unit side: J3098
      2. Check the connection between the Relay PCB (PCB5) and the High Voltage Unit. Relay side: J519, High Voltage Unit side: J3099
      3. Replace the Developing Assembly.
      4. Check the connection point of the Developing Assembly. If it is soiled, clean it.
      5. Check the connection inside of the High Voltage Unit. Check the connection of the High Voltage Unit Relay (J3097) and the Developing High Voltage PCB (J3511).
      High Voltage Unit Relay (J3099) and Pre-transfer Charging PCB (J3545, J3500, J3510)
      6. Replace the Main Driver PCB (PCB2).
      If you replaced the developer unit and the error went away, you've resolved it.
      I see nothing in the manual about those developer units being able to be repaired/rebuilt.
