IPF8300 trow error 2f43 after paper jam 2F13
  • silviu_25
    • Jan 2019
    • 27
    [Error Code] IPF8300 trow error 2f43 after paper jam 2F13
    Hi,
    I;m looking for help again for my cursed IPF8300.
    Yesterday I tried to print some canvas and for some reason carriage hung over the canvas returning 2F13.
    I turned off left 2 mins and ON again, started automaticaly to clean printheads and after long time trowed error 2f43.
    If I try to print something or to do a nozzle check the carriage is moving abnormally, is going to one side, stay there for 1 min then come back, stay one min and so on.
    If I load a cut sheet when is measuring the paper for some reason is smearing the paper.
    Please see attached photos.IMG_1062.jpgIMG_1063.jpgIMG_1064.jpgIMG_1065.jpgIMG_1061.jpg
    Any idea what could be?
    Re: IPF8300 trow error 2f43 after paper jam 2F13
    Originally posted by silviu_25
    Hi,
    Please see attached photos.[ATTACH=CONFIG]42727[/ATTACH][ATTACH=CONFIG]42728[/ATTACH][ATTACH=CONFIG]42729[/ATTACH][ATTACH=CONFIG]42730[/ATTACH][ATTACH=CONFIG]42731[/ATTACH]
    you have a buildup of ink from the jam.
    did you properly define the canvas as the print media? sounds like you didn't since the head jammed over the media.
    • silviu_25
      • Jan 2019
      • 27
      http://technique.davin.be/files/Trou...ng-Guide-E.pdf
      Yes, the canvas is registered into printer menu with head height highest and suction strongest but for some reason was a jam there.
      Any idea if I replace both printheads will sove the problem?
      I read over the Google someone else with same machine and similar ink problem, replaced both printheads but no luck...
      I can make a video with what exactly is happening if is needed but I'm afraid to not burn cariage PCB or motherboard due to faulty printheads
      • charm5496
        • 2387
        looks like your paper buckled and your carriage unit crashed into the paper and possibly damaged one or both of the printheads.
        • silviu_25
          • Jan 2019
          • 27
          What do you think? Replacing both printheads will fix it? Or I should expect for more parts to replace...?
          • silviu_25
            • Jan 2019
            • 27
            From service manual at 2f42 I have:
            "When the result of non-ejection detection is as follows:Complete non-ejection (640 nozzles) of EVEN line or ODD line.
            ・Error code assuming broken flexible cable or contact failure (data line)"
            Complete non-ejection since heads dropping ink This is strange.
            To broke flexible cable from a paper jam this is strange again.
            • silviu_25
              • Jan 2019
              • 27
              I replaced both printheads and now the problem is solved.
