these past few days our canon IR 3300 is asking for ID/Password though we are using it freely before w/o any ID/password to press..im sure nobody try to experiment to programmed it..To clear the problem ill go to function mode and clear the PWD..ok machne returns to its normal operation but again next morning the same old story begins.Also the current date settings changes.the copy settings which has been programmed also return to auto..can i asked for any suggestions..thanks a lot!!
canon IR 3300
BLITZKREAGG
BLITZKREAGG
Harshad
these past few days our canon IR 3300 is asking for ID/Password though we are using it freely before w/o any ID/password to press..im sure nobody try to experiment to programmed it..To clear the problem ill go to function mode and clear the PWD..ok machne returns to its normal operation but again next morning the same old story begins.Also the current date settings changes.the copy settings which has been programmed also return to auto..can i asked for any suggestions..thanks a lotComment
Harshad
these past few days our canon IR 3300 is asking for ID/Password though we are using it freely before w/o any ID/password to press..im sure nobody try to experiment to programmed it..To clear the problem ill go to function mode and clear the PWD..ok machne returns to its normal operation but again next morning the same old story begins.Also the current date settings changes.the copy settings which has been programmed also return to auto..can i asked for any suggestions..thanks a lot!![/quote]Comment
