C2020 no power
  • repeatcopiers
    • Sep 2008
    • 591
    C2020 no power
    Customer had power outage due to storm, no surge protector, now copier (Adv C2020) won't power up. We went out with an AC driver but that wasn't the problem. Any ideas before we waste another trip, its pretty far out. I figure we will take both Main Controllers, DC controller, low voltage and high voltage board and another on/off switch.
  • Andyboachie
    • 185
    Re: C2020 no power
    If it was working perfectly before the power surge, then ON/OFF switch might not be a culprit, but the board housing the ON/OF switch should be suspected. Expect a blown fuse or IC. Traveling with a working power board will be a shrewd idea.
    • Scottb
      • Apr 2013
      • 306
      Re: C2020 no power
      I would also make sure that the breaker to that plug isnt tripped
      • repeatcopiers
        • Sep 2008
        • 591
        Re: C2020 no power
        We ended up with power once we replaced the Main Controller.
