Canon MF 4890DW/Part Availiabilty
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    I went to a customer who has a Canon MF4890DW with a busted RIGHT HINGE upper frame unit(READER) THIS IS NOT the document feeder Hinge.The hinge
    for thje document feeded is an easy part number to find,However the hinge that opens when you lift open the READER assembly is broken.I have looked
    EVERYWHERE for the part number but I cannot find it.It looks easy to replace...Does anyone have the part number for the hinges that support the reader unit when opened?
    Both left and right.
    THANK YOU ANDY
  • axyun
    • Aug 2007
    • 1323
    Re: Canon MF 4890DW/Part Availiabilty
    I was looking thru parts catalog which shows different part #s depending on which model in series. Seems to separate them into dadf model,adf model and copyboard model. The MF4890DW is categorized as dadf model and according to listing the part# is FL3-9247-000. I am not familar with this machine but has service and parts manual. Someone else here may be familiar with modeland may be able to confirm part #. good luck with part and call. Frank/AP
    • cucuklotz
      • Mar 2007
      • 611
      Hi Axyun
      Thank you for the help.Still not sure that correct part # for the Hinges for reader section though.
      Andy
      • axyun
        • Aug 2007
        • 1323
        Does anybody out there service this model and have familiarity with this hinge breaking because
        it is difficult to find part # in parts catalog
        • axyun
          • Aug 2007
          • 1323
          • CS0523
            • Feb 2015
            • 35
            is it number 17 ?
            Part is:
            FC0-1638-000 HINGE, READER
            • cucuklotz
              • Mar 2007
              • 611
              Hi
              Thank you for Part #.I think that may be it,but cant find anyone who sells it.
              Thank you. Andy
