Black lines on printout of IR4570
  • A22COMPUTER
    • Sep 2016
    • 7
    Sirs, may I know the cause and solution of these heavy lines on printout of my Ir 3570 (see attached picture). I ruled out the drum unit and developer as the culprit, because these function well in other machine. Thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Black lines on printout of IR4570
    Do you hear clicking during printing?
    You can try to swap the laser.
    Check the drum contacts. A pin can be damaged.
    • A22COMPUTER
      • Sep 2016
      • 7
      None, no clicking was heard. Will try swapping the laser unit. Thanks.
      • zoraldinho
        • Mar 2008
        • 5007
        At the end, it can turn out to be bad electronic.
