c6010s jam code 0112
  • mc921
    • Oct 2015
    • 23
    Hello...i am installing a used c6010s in a customers office. everything is all connected and comes to ready just fine. Every copy jams over sensor ps200 (just before entering the fuser). I changed the sensor and the transport belts, and the motor. (all looks fine). Just for grins, i also changed the fixer feeder driver. Anyone have any thoughts? I re-seated all the connectors on the DC controllers. Any help would be appreciated.
  • teckat
    • 16083
    Re: c6010s jam code 0112
    Is it on all paper sizes & from all trays ?
    • mc921
      • Oct 2015
      • 23
      Correct. 1.2 million copies on the unit. Client bought on ebay...so no p print available.
      • NorthW
        • Jul 2017
        • 55
        Maybe a broken wire in that fuser guide assembly, is that sensor in the guide that flips up when clearing a jam? I remember the yellow fuser cover catching the wire loom at the top if not careful putting it in position.
        • mc921
          • Oct 2015
          • 23
          No... ps200 is in the transport assembly going into the fuser. This sensor has no flag.
          • NorthW
            • Jul 2017
            • 55
            My bad, that transport assembly kind of sticks out of the machine when the two halves are separated for shipping, could it possibly have been knocked during transport, so it isn't in correct alignment to the fusing station, that might cause the delay jam. Have you tried longer sheets?
            • mc921
              • Oct 2015
              • 23
              yep...tried all paper sizes. The assembly is mounted correctly, the 3 connectors are all intact, with new belts and a new sensor. Physically, all is fine. leaning towards the DC controller 1-1....
              • teckat
                • 16083
                0112----xx12 Pre-fixing feed sensor 2
                PS200
                01xx is a delay jam
                you stated ( Every copy jams over sensor ps200 ) wouldn't that be a Stationary Jam 02xx if paper is over sensor ?
                Pre-fixing feed driver PCB--check the connectors signals & Harness to and from
                I/O
                P005
                Bit 1= Pre-fixing feed sensor 2
                PS200 0: Paper is present
                • mc921
                  • Oct 2015
                  • 23
                  PS200
                  01xx is a delay jam
                  I/O
                  P005
                  [ATTACH=CONFIG]42914[/ATTACH]
                  The pre fixing feed driver was replaced, no change. I will be working on the unit this afternoon...will let you know. Thanks for the help!
                  • teckat
                    • 16083
                    first > important to check for change of state in I/O
                    I/O
                    P005
                    need to check all harness connections if no change of state is shown
