L36ei large format scanner on a canon TM300 cant find PC
  • Hansen88
    • 1069
    I am new to this model canon and the scanner. We set it up in the shop on our network and on the scanner when you do the search for pc it only finds one pc.We have two pc s with all the software set up. The second pc that it does not find can print to the wide format and the scan app is running. Seeing if anyone else ran into anything like this before. Thanks for any suggestions
  • V-P
    • Apr 2011
    • 679
    Re: L36ei large format scanner on a canon TM300 cant find PC
    As far as I remember the L36 scanner is able to scan (transfer data) to one PC.
    You install the application on the PC and choose which folder do you want your data scanned and that's it.
    Than if that folder is "shared across network" - you can access it from all network.
    Peace..
