E065-0001/E068-0001 on Canon IR Adv 6075
  • cobra
    • Dec 2011
    • 48
    [Error Code] E065-0001/E068-0001 on Canon IR Adv 6075
    I am working on this Canon IR Adv 6075. The first error was E065-0001. I replaced the Primary Charging assembly but error remains. I removed and clean the Primary Grid High Voltage connector. Check all the connectors in the High Voltage Unit. Now the error becomes E068-0001. Clean the Pre Transfer High Voltage connector but error remains. I'm inclined into replacing the Pre Transfer Charger Assembly. I have cleaned and checked the Pre Transfer Assembly and it looks ok. Any ideas? Thanks for your help
    COBRA
  • cobra
    • Dec 2011
    • 48
    Re: E065-0001/E068-0001 on Canon IR Adv 6075
    E065-0001 was fixed by Main Driver Board (PCB2) replacement.
    E068-0001 was caused by loose connector from the High Voltage Unit to the Relay PCB (PCB5).
    COBRA
