IRA 4251, Fax options
  • Atrat
    • Oct 2014
    • 18
    [Misc] IRA 4251, Fax options
    I'm trying to turn off the TX report for outgoing faxes,while leaving the TX report on. I've tried several times. I can only get either both on or both off.
  • mosey1100
    • Mar 2009
    • 143
    • Atrat
      • Oct 2014
      • 18
      Re: IRA 4251, Fax options
      Thank's for responding. It's just for the fax. They want outgoing fax TX report,Incoming fax TX report turned off. Thank's again !
        out going report TX
        in coming report RX ....
        if you look in the USERS GUIDE it should explain the fix.
        • Atrat
          • Oct 2014
          • 18
          I looked in the following GUIDES :Setup Guide, Basic Operations Guide and Before Using This Machine. There was nothing in there that relates to TX or RX reports. I looked on GOOGLE to see if there was any other Guides but none were available ,I also looked on the Canon website. If you can tell me where to get the correct Guide I would appreciate. Thank's for responding
          • mosey1100
            • Mar 2009
            • 143
            You can find it under Settings Registration > Function > Send > Fax > Fax Tx Report > turn ON with image. Turn off reports under Settings Registration > Function > Send > Common Settings > Tx Report & Communication Management Report.
            Sent from my iPad using Tapatalk
            • Atrat
              • Oct 2014
              • 18
              Thank's for the reply. Is there a Service Guide for faxes available. I mentioned in the previous post what I have ?
