canon imagerunner advance 525if iii no label paper type
  • n25an
    • Jul 2008
    • 1030
    on my 525if... I have no label papertype...
    I can set the custom papertype...
    Click [Settings/Registration] → select [Paper Settings] for <Preferences> → click [Paper Type Management Settings]. to label...
    but I am checking if there is anything else I can do such as adjust weight and such to make machine run custom papertype labels as labels...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • disamm
    • Oct 2018
    • 59
    Re: canon imagerunner advance 525if iii no label paper type
    Hi
    Strange then on my 525i ii i have labels --> but only in the Cassette 1 and 2. Seetings/Registration - Preferences - Paper Settings - Paper Settings - select the cassette and Set, Labels are there.
      from OP
      -or-
      driver?
      what tray ?
      need more specifics..
      maybe eve post config page?
      very few details.
      pissing in the wind to make ASSumption .
      • n25an
        • Jul 2008
        • 1030
        I did not think you could run labels through the trays... I was setting up labels through the bypass... and for me thats where its missing... when I get to the office... I will see if its available in 1 and 2... if its missing... it could be a firmware thing...
        nevertheless... question still holds...
        other than duplicating letter papertype and can change to make it feed the custom papertype like a label from the bypass...
        just trying to get an idea...
        until I can get a better look... at firmware
        • disamm
          • Oct 2018
          • 59
          Manual Feed not compatible with Labels
          • n25an
            • Jul 2008
            • 1030
            so labels feed from trays...
            can anyone confirm that trays on this machine don't jam with labels...???
            or can anyone recommend best labels besides laser labels... meaning best brand of laser labels to use on this machine...
            • disamm
              • Oct 2018
              • 59
              check this webpage https://mediaguide.oce.com/ here you can find the paper catalogue that canon recommends.
              • n25an
                • Jul 2008
                • 1030
                Thanls
                • roho
                  • Mar 2009
                  • 844
                  I have a couple customers that regularly run labels from the cassettes on the 5200 series. Rollers wear faster, but seems to work fine. They have the one tray dedicated to them.
