Service Mode Password c7260
  • nkolee
    • May 2018
    • 14
    Hey there. I have a Canon Advance c7260 that I purchased used. I am trying to go into service mode but am unable to do so because of a password required. After I enter service mode another window pops up that says: Certification (Service Technician) Enter the Password.
    I have tried the defaults 11111111 and 7654321. I do not have access to the Service Support Tool.
    Is there a way to bypass and reset this? Thank you for your help!
    Nicole
  • mosey1100
    • Mar 2009
    • 143
    Re: Service Mode Password c7260
    You need the Service Support Tool in order to reset the password.
    Sent from my iPad using Tapatalk
    • nkolee
      • May 2018
      • 14
      • teckat
        • 16083
        Nicole
        as noted above by mosey1100
        CAUTION:
        If you forget the password for service technician, disable the password function using the Service Support Tool (SST).
        Security Support
        A password can be specified to prevent unauthorized access to the service mode.
        Related Service Mode:Procedure for Setting PasswordService technician
        CAUTION:
        • khaled_mohamed
          • Mar 2019
          • 6
          CAUTION:
          Security Support
          CAUTION:
          Welcome Welcome mr:teckat
          Sent from my SM-J700H using Tapatalk
          • teckat
            • 16083
            Nicole
            added info
            Initializing All Data which is found under :
            Settings/Registration>Management Settings>Data Management>Initialize All Data/Settings
            believe may work to clear all Passwords
            • nkolee
              • May 2018
              • 14
              Thank you all for your help! I was able to get the SST along with the correct firmware to remove the service mode technician password.
              Thank you very much for your replies-much appreciated! ๐Ÿ˜€
