Can't login to RUI on 256if after setting up department codes
  • n25an
    • Jul 2008
    • 1030
    Ok... before setting up department codes
    login from rui
    login 7654321
    pass 7654321
    after setting up codes
    I could login as admin on machine with
    login 7654321
    pass 7654321
    But could not login on rui
    here is what was tried
    login 7654321
    pass 7654321
    login Administrator
    pass 7654321
    login administrator
    pass 7654321
    login Administrator
    pass 1234567
    login administrator
    pass 1234567
    login 1234567
    pass 7654321
    login 1234567
    pass 1234567
    login 7654321
    pass 1234567
    From the copier... I was able to solve all department code problems... but it would be nice to be able to
    1. get back into the rui
    2. be able to clear the department code off completely by loging into the rui... or service mode...
    3. be able to edit department codes from in the rui...
    as always any help is appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • darkocg88
    • Jan 2018
    • 63
    Re: Can't login to RUI on 256if after setting up department codes
    Gotta change default pw for admin to be accessible via RUI.
    Sent from my Moto E (4) Plus using Tapatalk
    • n25an
      • Jul 2008
      • 1030
      ok... how do I do that???
      • darkocg88
        • Jan 2018
        • 63
        Copier menu. System settings. You should manage from there.
        • n25an
          • Jul 2008
          • 1030
          So you are saying change system mgr password...
          Then that should unlock rui...
          By going where you directed...
          Interesting....
          • darkocg88
            • Jan 2018
            • 63
            Interesting....
            Yup. Logically, if adm system password anyone that knows IP would be able to use admin RUI.
            • n25an
              • Jul 2008
              • 1030
              #1 Ok... I took a look at an imagerunner advance c250if service manual... I know not a c256if...
              Here is something I found...
              on page 2-201 of the service manual it lists
              Remedy to Be Performed When the Device rui Has Become
              Unable to Be Logged in...
              is that what you were thinking...
              meaning...
              create dept id 7654321
              create pass 7654321
              will fix issue...
              or
              #2 just set a code for the system mgr...
              I am thinking you mean #1
              thanks for the two options...
              I used to have access to canon technical bulletins... but I no longer have access... new job... could someone check if this issue is dealt with there... to verify that this holds true for 256if and newer copiers
              search term -- Remedy to Be Performed When the Device rui Has Become Unable to Be Logged in...
              search term -- rui unable to be logged in...
              • JParker
                Technician II
                • Jul 2015
                • 51
                Have you tried doing a pw clear through service mode on the mfp?
                • n25an
                  • Jul 2008
                  • 1030
                  it was the web browser...
                  cleared the cache...
                  took computer web browser back to factory...
                  all is well login/ pass 7-1
                  it was the computer web browser...
