IR6570 restarts continuously
  • Prashantha.PS
    • Nov 2012
    • 9
    [Misc] IR6570 restarts continuously
    IR 6570 on and off continuously. touch panel not working sometimes
    Re: IR6570 restarts continuously
    End User?
    try:
    seeing if any ctl pnl button is stuck
    is there an error code on dislpay
    how far into boot process does it get?
    YOU provide -=NO=- info
    PhilB " The Dentist"
    • Prashantha.PS
      • Nov 2012
      • 9
      Sorry I am poor in English, Actually Error Code E-004-0010, shows that time IH Board Fuse blows So i changed the IH Board, after changing IH Board, Machine Booting and it shows ready to copy then restarts automatically
      • teckat
        • 16083
        Pull the memory_clean ends_re-seat.
        Check the Fuser Harness on Printer Side.
        • Prashantha.PS
          • Nov 2012
          • 9
          Thank you Tecket for your reply Sir I didn't Get the point please explain where to check.
          • Prashantha.PS
            • Nov 2012
            • 9
            Sir please explain how to check
            • Prashantha.PS
              • Nov 2012
              • 9
              Thank u Sir Problem solve, Know White copy coming
              • teckat
                • 16083
                how was it solved ??
                white copy ?
                u mean completely blank on a constant run > with no error codes
                • Prashantha.PS
                  • Nov 2012
                  • 9
                  white copy ?
                  Sorry For Delayed reply and Thank you teckat, check as you said and then the RAM changed, and all the connectors checked again, the restart issue is OK, But Blank copy With No Errors.
                  Po-count 1 makes dark copy, Po Count 0 makes light copy, belt checked It is correct. The Primary Corona assembly changed, Potential Sensor unit also changed, The drum polish is just outstanding.
                  • teckat
                    • 16083
                    sorry for my ignorance
                    what is Po Count 1 / Po Count 0
                    u mean issue on Glass Copies
                    or Network Prints_____________or Both
                    • Prashantha.PS
                      • Nov 2012
                      • 9
                      Issue on Both prints.
                      I have changed all corona wire.in setting panel i have tried *28*<copier then <option < body< po-cnt<0. Which is giving dark copies and
                      *28*<copier then <option < body< po-cnt<1 which is giving very light copies and waiting copies problem occurs
                      please suggest the possible solutions
                      • teckat
                        • 16083
                        DC
                        controller PCB.
                        or High-Voltage Transformer
                        have u checked "The Laser Output"
                        how old is Drum
