It is the problem with heater,thermistor,or termal fuse unit.Try to reset your copier.If that helps,that's the solution.If it is not,use your multimeter to chek heater or thermal fuse.
That error ussualy happens becouse of cold space around the copier.That room must be heated for min. 30 minutes,to rich min. 18'C-20'C before you can use the machine.
