New install IPC6010 error E866-202-11
  • mc8305
    • Aug 2014
    • 12
  • fchu5959
    Field Engineer
    • Jun 2010
    • 100
    Re: New install IPC6010 error E866-202-11
    Hi
    Welcome to the world of Canon.
    check the attached file;hope it could help you for troubleshooting.
    Cheers.
    • mc8305
      • Aug 2014
      • 12
      Thanks!
      Checked all connections, but found no problems, still the same
      Any other hints before i start to swap prints?
      • mc8305
        • Aug 2014
        • 12
        • teckat
          • 16083
          E866, 0202
          Check J7969, an in-line connector going to the Lower Deck Indicator Driver PCB.
          This connector is located behind the cover on the right side of the lower deck when pulled out of the POD.
          It may be disconnected or the pins may be making poor contact.
          • teckat
            • 16083
            E866-0202 Error Code at Power On
            Example of Testing
            The Lower Deck Indicator Driver PCB (PCB804) was swapped with the Middle Deck Indicator Driver PCB (PCB 704) but the sub code did not change.
            An on-site example find-------
            The POD Deck-A1 was connected to a Surge Protector that was not functioning properly.
            The resolution was to plug the POD Deck-A1 directly to the AC wall outlet and remove the Surge Protector.
            • teckat
              • 16083
              Dropbox - POD_Deck-A1_SM.pdf - Simplify your life
              Dropbox - POD Deck-A1_ Install.pdf - Simplify your life
              • mc8305
                • Aug 2014
                • 12
                Thanks to both fchu5959 and Teckat for excellent advice!
                It ended up being the j7969 connector I apparently didn't check it properly the first time... now pushed all the way in and POD deck online
                • fchu5959
                  Field Engineer
                  • Jun 2010
                  • 100
                  Good job.!You are welcome.
                  • teckat
                    • 16083
                    ELVIS.jpgTHANKS
