Error 733-0001 in Ir 8070
  • abkonnet
    • Mar 2008
    • 166
    [Error Code] Error 733-0001 in Ir 8070
    Face the error code issue 733-0001..
    Format the HDD and re install firmware.. machine turns on everything seems ok ... after turn off and turn on the machine during boot time machine get restarted and machine throws the error again...I checked all connector in DC controller pcb and in main board...
  • abkonnet
    • Mar 2008
    • 166
    Re: Error 733-0001 in Ir 8070
    Some body have any idea for rectifying this problem
      how are you "shutting machine off"? Improper shutdown can corrupt data on the HDD.
      did you follow ALL the steps in the manual when reloading HDD?
      Most here are full time or retired techs. Sometimes we cannot reply within a short period.
      Your Post has only been up for 24hrs.
      Have you talked to Canon Corp about your problem? ( you are a certified Canon Tech ... right?)
      • abkonnet
        • Mar 2008
        • 166
        No I am not a certified tech...I have changed firmware number of times so HDD firmware installing is not a problem... Actually the registration clutch of the machine is not working while checking the fault this error has come out.
