Canon IR2018 Paper not Correct
  • Andyboachie
    • 185
    I'm working on an IR2018. During copying, there has been continuous error of paper jam. Whenever the jam occurs, there is a message of: "Paper not correct. Change paper". It results in the copy appearing blank halfway I've tried resetting the cassette to different paper sizes but it happens the same way. I have changed the registration clutch, but that too does not work. Does anyone have an idea of what else I should check? I will appreciate your kind suggestions.
  • ahmad
    • Jun 2010
    • 28
    Re: Canon IR2018 Paper not Correct
    open the cover and see the distance of the scanner it takes when making copy
    you can reset the copier enter the service mode and make clear all
    • Andyboachie
      • 185
      Originally posted by ahmad
      open the cover and see the distance of the scanner it takes when making copy you can reset the copier enter the service mode and make clear all
      Hi,Thanks for the response. Yes I initially entered service mode. But it came again. I'll next check the position of the scanner as well when I get there. I'll get back with info asap.
      • teckat
        • 16083
        Check the action of Registration Flag,
        • Brian8506
          • 1665
          This may be your problem. Looks a little involved getting to the gears.
          • teckat
            • 16083
            Originally posted by Brian8506
            http://www.techsupport.cusa.canon.co...cle&AttIndex=0
            Bad Link😣
            The file could not be loaded. Either you do not have permissions or the file could not be found.
            • Brian8506
              • 1665
              Strange. It opened for me and then it wouldn't. Hope this is it.
              http://www.techsupport.cusa.canon.com/kb/article?ArticleId=64574&cid=990&download=true&isli nk=true&source=article&AttIndex=0
              If not, it's tech pub TP07 268.pdf
              • teckat
                • 16083
                Nope >;-(
                Believe u need to be logged in on Canon Tech Support to view.
                • Brian8506
                  • 1665
                  PM me your email and I will try to email you the tech pub. There are 2 updated gears, 1 in each paper feed unit. We can't seem to open the link on here.
                  • Andyboachie
                    • 185
                    Hi,
                    Good suspicion! I will do that when I get there today. However, I remember the paper used to go a little beyond the registration flag. It mostly stopped just about when it is about to enter the fuser before displaying "Paper not correct"
                    • laitang
                      • Nov 2012
                      • 627
                      I solved the problem by prolonged registration flag.
