Grinding noise on ir3045
  • Shahn
    • Aug 2017
    • 30
    the noise seems to come from behind of developer unit, The developer unite spins smoothly,
  • Brian8506
    • 1665
    • hidius
      • Jun 2015
      • 128
      Re: Grinding noise on ir3045
      you can run a motor test and check which motor is causing the noise
      • Shahn
        • Aug 2017
        • 30
        Copier->Function->Install->TONER-S in service mode also makes the same noise
        • hidius
          • Jun 2015
          • 128
          looks like a gear in the hopper unit. take the dev unit out and vacuum the pipe where the toner comes into the dev unit. if that doesn't fix it then replace the hopper
          • Shahn
            • Aug 2017
            • 30
            i vacuumed inside the machine but the sound is still there
            • Brian8506
              • 1665
