canon,D861
  • hodgiepodgie
    • Jul 2008
    • 284
    canon,D861
    Can anyone give me some info on how to replace a "fuser unit" on a canon d-861?
  • Funnyfarm69
    • Jun 2008
    • 51
    This is the instructions as per the manual.
    Removing the Fixing Assembly
    1) Remove the delivery upper cover/rear cover
    2) Disconnect the 3 connectors.
    3) Remove the control panel.
    4) Remove the copyboard glass.
    5) Remove the cover
    6) Slide the reader unit so that the hole in the reader unit and the hole in the top
    plate match.
    7) Remove the 3 screws and detach the fixing assembly
    Memo
    To remove the screw used to secure the fixing assembly in place, try removing
    the screws from above the reader unit using a long screwdriver (i.e.,make use of the opening above the screws to facilitate the work).
    When mounting the fixing assembly, be sure to engage the gear of the fixing assembly and the gear on the main motor side.
    Good Luck
    sigpic MINES A PINT!
