E197-2003 on a canon c5535
  • canon911
    • Aug 2019
    • 4
    Hi can anyone help? Regards
  • guitar9199
    • Sep 2016
    • 1097
    Re: E197-2003 on a canon c5535
    E197-2003-05 Serial communication error
    Description: A communication error between the DC Controller PCB and the Main Controller PCB was detected.
    Remedy [Related parts] R1.00
    - Harness between the DC Controller PCB (UN1/J100 and J101) and the Riser PCB (J2 and J10)
    - Connector between the Main Controller PCB and the Riser PCB
    - Riser PCB
    - Main Controller PCB
    - DC Controller PCB (UN1)
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2
    min) and restore the backup data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES
    <Translation: Reseat all your boards and connectors and boot it back up.>
    • canon911
      • Aug 2019
      • 4
      Thanks pal, I saw all this on the service manual today
      Its the solution I need please
      • canon911
        • Aug 2019
        • 4
        I have tried to re seat all the connectors with no success
        • guitar9199
          • Sep 2016
          • 1097
          Got it. I'd START with the DC Controller. If that doesn't work, then the Main controller.
          Wish I had a better answer, but that's how Canons are.... Once you've checked the easy stuff, then it's time to replace boards- VERY little "in between".
          • canon911
            • Aug 2019
            • 4
            Ok thanks pal. We are an independent canon dealer with a lot of history on kit. Just wondered if you had come across the same issue?
            all the best
