canon ir3225 black lines
  • cowking
    • Apr 2019
    • 5
    I have a canon imagerunner 3225. I have black lines that come a good way down the sheet, they start at top and work their way down, maybe 1/2 way. They repeat every 40mm which would tell me if this is a roller it has a 12.75mm diameter. The lines seem to get lighter when there is less toner on the page and increase with more toner printed on the page. I replaced the drum with a drum rebuild kit, it did not fix the problem. Is this the fuser?
    Re: canon ir3225 black lines
    [ATTACH=CONFIG]43321[/ATTACH]
    well ...
    1) OEM genuine or compatible drums/toner?
    2) did you thoroughly clean all:
    feed/transfer/guides/transport/laser areas?
    3) copy or print?
    4) life of consumables?
    5) end user or tech?
    6) print out of consumable/service parts life?
    frankly... -= IF=- you really want help you should give AS MUCH information for us to go off
    of.
    PhilB. " The Dentist "
    • hidius
      • Jun 2015
      • 128
      looks like the dev unit. pull it out and clean the mag roller
      • redzventures
        Service Tech
        • May 2009
        • 45
        • cowking
          • Apr 2019
          • 5
          well ...
          3) copy or print?
          of.
          Sorry I'm new to posting here.
          1) I use oem toner but non oem drums
          2) I have cleaned those area with a dry lint free cloth
          3) both copy and print
          4) I'm not sure what that means, the toner is probably changed every month, this has been going on now for at least 6 months
          5) I'm an end user
          6) I don't have a print out of the parts life, most would be original, and we are looking at 10 years or so.
          Someone else asked about the way I was holding the paper, I believe that my picture got rotated some how in the download process. I was printing where the long side of the paper comes out of the machine first, portrait.
          So I'll check out the dev unit and the mag roller and also the heat roller. Thanks
          • redzventures
            Service Tech
            • May 2009
            • 45
            • cowking
              • Apr 2019
              • 5
              I'm a pastor actually, but I like tinkering, I've had this whole thing taken apart before, clogged hopper, installed a new finisher. I've even designed and 3d printed improvements to the rollers and have 3d printed new gears. (If anyone wants weighted finisher rollers let me know, they grip way better than oem). So I'm not really afraid to try anything.
              I tried printing all black, and as the picture will show where it used to leave black lines they are now kind of white. (PS picture is rotated 90 degrees again I don't know why)
              • cowking
                • Apr 2019
                • 5
                I'm not sure if my reply went through or not, sending the picture again. I tried printing in all black this is what I got. The picture is probably rotated, it did come out of the copier long side first.
                • cowking
                  • Apr 2019
                  • 5
                  going off the dev mag roller suggestion, I went in and sure enough that mag roller had some gunk on it. After quite a bit of elbow grease got it off and now have beautiful prints again. Thanks guys!!! Problem solved.
