Remove Paper From Output Tray Canon C5235i
  • denvertan
    • May 2019
    • 82
    [Error Code] Remove Paper From Output Tray Canon C5235i
    This error strike after the copier is with the customer for a month++.
    I sticking a tape to cover the sensor near the output tray which temporary stop the message.
    I suspected this error is cause by a inner finisher is removed. And some parts is not properly installed.
    Can someone share with me the service manual so I can fix it. Thank you.
  • chili
    • Aug 2017
    • 4
    Re: Quitar papel de la bandeja de salida Canon C5235i
    Efectivamente es por que tenia un finisher interno y al quitarselo le tienes que poner un flat para evitar el mensaje de papel en la bandeja.
      Re: Remove Paper From Output Tray Canon C5235i
      manual requests should be made in this forum:
      http://www.copytechnet.com/forums/se...nual-requests/
      • hidius
        • Jun 2015
        • 128
        when you remove the inner finisher you have to put back the stack full sensor flag which is removed during the installation.
        • Megatsimepe
          • Sep 2019
          • 3
          Please check the Sensor flag Within Where the Tray is.
