C3520i print issue
  • darkocg88
    • Jan 2018
    • 63
    C3520i print issue
    Tried switching fixing film unit, changed belt, drums, cleaned laser. Same result.
    Any help is highly appreciated.
    Br.
    Sent from my Moto E (4) Plus using Tapatalk
  • teckat
    • 16083
    Re: C3520i print issue
    Br.
    does smear issue travel on continuous printing ?
    paper feed or cross-feed direction
    • darkocg88
      • Jan 2018
      • 63
      Yeah it travels.
      • nicknt82
        • Nov 2011
        • 155
        Br.
        Do you check Cleaning Belt? check if any piece of paper drop inside
        • Service@PRT
          • Oct 2016
          • 181
          Br.
          remove transferbelt and Clean the sensor underneath. You can clean it by removing transferbelt and from the leftside of the machine. Clean the 3 sensor.
          Sent from my HUAWEI VNS-L21 using Tapatalk
          Every day of life is a learning process...
          Just make sure you are open in all aspects of comments.
