E000490-001 on 7105 - suddenly !
  • yazan
    • Feb 2011
    • 15
    [Error Code] E000490-001 on 7105 - suddenly !
    hi please i need your help , i just got the E000490-001
    suddenly after starting the machine , if the feeder is connected the machine stuck and hang in the booting ( wait ) msg
    i plugged the feeder after the machine start then it throw the code ,
    nothing changed in the machine !
  • roho
    • Mar 2009
    • 844
    Re: E000490-001 on 7105 - suddenly !
    Turn the device off. Unplug from wall. Reseat connectors for the feeder/reader, make sure they are connected. Plug back into wall. Turn on.
    After the device boots up, do you still have error code? Report back.
    • yazan
      • Feb 2011
      • 15
      i did it many times ,
      after rebooting no codes "with the feeder connected" , but the machine hang and stop in the booting/loading with wait msg
      • roho
        • Mar 2009
        • 844
        Depending where the status bar hangs, you may or may not get into service mode. Try going into service mode and see if there is a error condition.
        If you can get into service mode, try deactivating the scanner status, and power off. Disconnect the reader and try rebooting then. If the scanner/reader is hanging the device this step should confirm it.
        • yazan
          • Feb 2011
          • 15
          yes i can log in to the service mode level 1
          btw no red light bulb indicator is flashing
          no codes , please how to deactivate , in the accpst-d only finisher is shown
          • roho
            • Mar 2009
            • 844
            E490 -0001 -04 Title DADF model mismatch error
            Description
            of detection
            DADF that is not supported is installed.
            Measures 1. DADF of a different model is installed.
            2. Failure of the reader controller PCB (PCB1)
            3. Failure of the DC controller PCB
            4. Failure of the main controller PCB
            You do not see the reader/feeder in service mode? I would check over the reader connections, external to the device for damage, and the internal ones to see if perhaps a ribbon cable is loose. Once you move past that stage looks like a control board issue.
            • yazan
              • Feb 2011
              • 15
              Description
              of detection
              the untold story from owner.
              they told me today they send the feeder to someone while iam in vacation , he fix a sensor as told , and its like this since they receive it.
              trying to contact that man , he was outside the country
              • roho
                • Mar 2009
                • 844
                It could be just about anything at this point! Clipped/ pinched wire, bad PCB. Could be a issue with reassembly, or damaged in shipping. The only good news here is that it will be something with the feeder so you cak forget about the DC controller and the devices main controller.
