canon ir Advance 8105
  • imran181070
    • Aug 2016
    • 24
    [Misc] canon ir Advance 8105
    dear all
    help is required for 8105 finisher is not staking loose ,but with staples perfectly staking
    replaced finisher controller & upgrade the firmware with latest
    any help ll be appreciated
    regards
  • teckat
    • 16083
    Re: canon ir Advance 8105
    Originally posted by imran181070
    dear all
    regards
    not staking loose
    • imran181070
      • Aug 2016
      • 24
      Originally posted by teckat
      not stacking ,thro 1 set on another top of set ,
      • techandtrader
        • Jun 2016
        • 318
        Hes only Stacking good when stapling I think that is what he means.
        Run the adjustment or check age of flappers? What is the count in service more for the finisher parts? Maybe new flappers will stack standard prints....no staple.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • Momiowilove
          • Sep 2019
          • 63
          What is the jam code
          • Arcadian
            • Feb 2010
            • 218
            when you turn on the printer does the stacker does it dance, goes up and down?? if not the fucntion of tyhe stack is possibly off you have to goto tech mode and turn it back on. i think it somewhere along the line techmode, stacker, adjust, then there might be a number 38 or something. you have to clear that number, just highlight the left then hit 0 on keypad. i know im talking out from memory here. i could be wrong. i had that issue a while back but clearing the code then restarting the machine made the sorter come back to life. there could be a broken actuator, make sur eall actuator are working.
