ir3045
  • akm
    • Sep 2012
    • 155
    [Error Code] ir3045
    Dear/ CopyTechTeam,
    I face a problem with canon ir 3045 that works good when makes one side but the problem appears when makes two sides it stops opertation without display any jam and the
    screen appears that printing without any thing the error code 240 , error 732
    thanks
    akm
  • JParker
    Technician II
    • Jul 2015
    • 51
    Re: ir3045
    Have you re-seated the ribbon cable?
    • guitar9199
      • Sep 2016
      • 1099
      Re: ir3045
      E240 error (communication error between the main controller and DC controller) has
      occurred, the drive system may still continue operating.
      E732 There is an error in the communication with the scanner.
      Sub code 0001 There is a DDI-S communication error.
      1. Check the connector used to connect the scanner.
      2. Check the power supply of the scanner (to see if initialization takes place at
      startup).
      3. Replace the reader controller, scanner board, or main board as necessary.
      Sub Code 0010 Fault in detection of DDI-S Vsync signal
      Sub Code 9999 A scanner is first detected from the printer model. (Not an error code but only the message 'Turn the main power switch OFF&ON again' is displayed on the
      users screen.
      The error is recorded in service mode > DISPLAY > ERR. Turn the main power switch off/on
      First thing I would do is remove the rear cover and reseat ALL the connections on the Main Board, Reader Controller and Scanner Board. Test operation and if it continues failing, start by replacing Main Controller.
      • akm
        • Sep 2012
        • 155
        Re: ir3045
        startup).
        users screen.
        many thanks for your reply i reseat all the connections on the dc controller ,main controller but the error appears again
        • nicknt82
          • Nov 2011
          • 154
          Re: ir3045
          Originally posted by akm
          Dear/ CopyTechTeam,
          thanks
          akm
          Try replace new Drum unit or good one
          • Herrmann
            • Jan 2006
            • 792
            Re: ir3045
            Sounds for me, if the Power Supply for the Reader is gone
            Check in that Direction
            greetings from Germany
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • sureshraidu
              • Oct 2011
              • 28
              Re: ir3045
              Try replacing duplex motor. I've solved same problem with duplex motor.
              Sometime it was showing 733 too.
              Dear/ CopyTechTeam,
              thanks
              akm
              Sent from my Moto G (5S) Plus using Tapatalk
