Any sugestion is WELLCOME.
"The triac is idendified to have a short circuit"
First. I check the triac and it is OK
Second .If the thermistor conector is first removeved from Main Board ,the error is E-000
.This show that DC Controler PCB work ?!?!
The fuser lamp has 4-5 ohms at "cold".
I know to reset the error code from service mode but no way .
Thank you
Thank you
