Image Runner c5030i
  • Megatsimepe
    • Sep 2019
    • 3
    [Error Code] Image Runner c5030i
    Hi Family Am having problem with a client Machine Canon Image Runner C5030i.It has been showing this Error code E00074-002?Please can someone help me out??
  • guitar9199
    • Sep 2016
    • 1100
    Re: Image Runner c5030i
    Primary Transfer error.
    E074 0002 Error in engagement
    Primary Transfer Detachment Sensor 2 failed to be detected for 2 sec at the time of engagement operation
    Remedy
    1. Check if the ITB Connector is physically removed.
    2. Replace the Primary Transfer Detachment Motor (M15)
    and its Drive Assembly (the gear, Drive Shaft, Mounting
    Plate, etc.).
    • Megatsimepe
      • Sep 2019
      • 3
      Re: Image Runner c5030i Error Code E00074-002
      Remedy
      and its Drive Assembly (the gear, Drivethe gear, Drive Shaft, Mounting
      Plate, etc.).
      Please can you help me locate where the primary transfer detachment motor(M15) is and the gear, Drive Shaft, Mounting
      Plate(Where it can be found)
