Jam code 000203
  • Momiowilove
    • Sep 2019
    • 63
    Jam code 000203
    Good day to all
    i have a canon ir 8105 when i start copying 2 sets in duplex mode. Suddenly the first set i ciming completely but when the last set is copying 000203 jam code occurs. I already clean the vertical path section and all the sensor in it and i clean already the all tge vertical roller and i replaced a new feed roller. Can you help me. How can I solve the problem. Thank you
    Re: Jam code 000203
    Originally posted by Momiowilove
    Good day to all
    how many pages on parts and supplies?
    how long has it been doing this?
    can you posts pics of the paper jammed ?
    • teckat
      • 16083
      Re: Jam code 000203
      Good day to all
      Put xtra wrap on spring
      • Momiowilove
        • Sep 2019
        • 63
        Re: Jam code 000203
        What is the location of the sensor that i will put a extra wrap?
        • teckat
          • 16083
          Re: Jam code 000203
          Try vertical first
          • Momiowilove
            • Sep 2019
            • 63
            Re: Jam code 000203
            The vertical path is a photosensor there's no flag sensor there
            • teckat
              • 16083
              Re: Jam code 000203
              right, sorry thinking of another issue.
              Is issue from running paper out of Right Deck ????
              or
              from cassette 3 or 4 ???
              Try replacing the bushings on the vertical path rollers with bearings .
              There are two sizes of bearings used. For the front (XG9-0709-000) and for the rear (XG9-0466-000)
              Check that the wiring harness that goes from the feed assembly to the Feed Driver PCB is not damaged.
              if so >>Replace the harness ( FM4-1035-000 )
              also
              Try replacing PS24 .
              PS24 is the Vertical Path Sensor 1, and can be checked in I/O mode > P-Sensor > DCCON > P012 - 8 > 1=Paper present.
              Also, check the wire harness & connection that goes to PS24.
              PS24 part number is FK2-6470-000
              Sensor cable harness part number is FM4-1001-000
              • Momiowilove
                • Sep 2019
                • 63
                Re: Jam code 000203
                I just replace that sensor. I get the sensor in tge good runnubg unit but the jam error is still occurs.
                Sent from my RNE-L22 using Tapatalk
                • Momiowilove
                  • Sep 2019
                  • 63
                  Re: Jam code 000203
                  All of cassettes from 1 to 4 cassette. I tried to replace all the vertical rollers and i tried to clean the registration and duplex paper path but still it occurs 000203
                  • Momiowilove
                    • Sep 2019
                    • 63
                    Re: Jam code 000203
                    Good day mr teckat. Can you please tell where is the location of the Gripper Motor (Finisher-D1) canon ir 8105 bcos i have a problem error occurs E514-8006
                    Thank you so much if you have a manual of this finsiher can you send to my email marvie.longgos07@gmail.com
                    • teckat
                      • 16083
                      Re: Jam code 000203
                      https://www.manualslib.com/manual/1190769/Canon-Imagerunner-Advance-8085.html?page=144
