Canon ir 2230 jam trouble
  • cpiga
    • Sep 2019
    • 7
    I have a canon ir 2230. If I load paper in the bypass tray always work. If I get paper from Tray 1 and Tray 2 I have
    Jam code 102 -> PS11 sensor
    Jam code 105 -> PS9 sensor
    I tried to change two of the three feed rollers for each tray but without success.
    Any suggestion?
    Carlo
    • 22808
    Re: Canon ir 2230 jam trouble
    I tried to change two of the three feed rollers for each tray but without success. Any suggestion? Thanks Carlo
    what paper is loaded in tray 1& 2?
    what does the copier think is in those trays?
    what size type does the computer think is in the trays?
    are you sure the trays are adjusted properly?
    • guitar9199
      • Sep 2016
      • 1097
      Any suggestion?
      Carlo
      How many pages on this machine? If it's close to/over 150K, replace all the feed rollers.... INCLUDING the Separation Roller assembly for Cassette 1.
      RM1-6175-000 -Pickup Roller
      RM1-6176-000 -Separation Roller assy
      FB6-3405-000 -Roller Paper Pickup (Cass 2-4)
      FC6-6661-000 -Separation Roller (Cass 2-4)
      FC6-7083-000 -Roller, Feed-Separation (Cass 2-4)
      Good luck.
      • cpiga
        • Sep 2019
        • 7
        The paper loaded in tray 1 & 2 is plain A4 paper correctly recognized in the display and correctly sets up in the rotary selector in the tray.
        • cpiga
          • Sep 2019
          • 7
          Good luck.
          The machine has around 70k copies.
          thanks
          • Brian8506
            • 1623
            • cpiga
              • Sep 2019
              • 7
              Good luck.
              I make a search on google. I have already changed "FB6-3405-000 Roller Paper Pickup (Cass 2-4)", "FC6-6661-000 Separation Roller (Cass 2-4)", "FC6-7083-000 Feed-Separation (Cass 2-4)".
              I searched the service manual for "RM1-6175-000 -Pickup Roller", "RM1-6176-000 -Separation Roller assy" and I didn't found anything.
              Can you help me to locate this part inside the copier or inside the service manual?
              Thanks a lot for the help.
              Carlo
              • Jhn16
                • Sep 2019
                • 7
                Any suggestion?
                Carlo
                Any sign of paper picked up? when the paper picked up where it stacked??
                • Brian8506
                  • 1623
                  I assume this is for the old black-and-white copier not the advance color. The RM numbers or rollers for a color machine
                  • guitar9199
                    • Sep 2016
                    • 1097
                    Carlo
                    Is this the Color Advance series C2230? If not, then I gave you the wrong part numbers.
