How to reset the counter meter by canon iRxxx E-CODE E350 ,E355
  • ninja copy
    Copier repair
    • Mar 2008
    • 24
    [Error Code] How to reset the counter meter by canon iRxxx E-CODE E350 ,E355
    Serial EEPROM available
    Universal Device Programmer
    1.counter pcb
    2.
    Serial pcbManage with superpro-580u-programmer
    You have to copy
    1.counter pcb
    2.Serial pcb
    From another device with Manage with superpro-xxxu-programmer
    From another device Read, keep and save to E355
    E355 on IR ADV 6075
    1.service mode * 1 7 + 3 9 * FACTORYmode 2.select 01 [ ALL RAM CLEAR ]
    3.select E35* CLEAR & ALL RAM CLEAR [-] 4.select KeyPad NUM 2
    5.select OK 6.Wait for the system to reset the system. And up to E355 and turn off the machine
    7.Assemble COUNTER,SERIAL 8.Turn the device into the normal screen
    binary file download for test
    How to reset the counter meter 0000000 copier , counter check ~ Copier repair Insurance
  • alex@wocltd.com
    • 430
    Re: How to reset the counter meter by canon iRxxx E-CODE E350 ,E355
    what are you doing to read and program eco board? and what chipset?
    and why not just do fram init on counter board? also no mention of how to clear e355 - gonna suggest srv mode lv3?
      [ATTACH=CONFIG]43593[/ATTACH]
      1.counter pcb
      2.
      You have to copy
      1.counter pcb
      2.Serial pcb
      E355 on IR ADV 6075
      so you are using this device to turn back ALL counters including main total counter?
      what is the purpose, other than to run a scam saying it's a new machine?
      IN FACT in America that is a Crime... it's called FRAUD and if that is the intent of this post.. you could lose your account here.. and frankly I would support Admin's move on that whole heartedly.
