imagepass M2
  • dpepin
    • Dec 2007
    • 51
    imagepass M2
    Hi to you all ! and Happy new Year!
    i don't know if i would be lucky this time. i have 2 imagepass M2 doing the same thing. i just bought
    them. the problem is when the imagepass is connected with the copier the screen display "connection established" but i can't access the run setup cause the unit doesn't get to the idle state. i really don't know how to resolve that issue so if you have the answer tell
    me i would appreciate.
    thanks
    Denis
  • SCREWTAPE
    • Jul 2025
    Did you try reloading firmware?
    • dpepin
      • Dec 2007
      • 51
      yeah
      yes i have tried to reload the software but still the same screen. i have replaced the crossover cable between the copier and the image pass, also i have tried another image pass from another machine, still the same. this one is a funny one ????
      • Canuck
        Tech Specialist
        • 1713
        Get the user software discs...ran into this problem..after installing system software on RIP you need to install user software on RIP
        • dpepin
          • Dec 2007
          • 51
          found it !!!
          i found it the problem was the little connector board, not seated firmly in the motherboard
          thanks
          Denis
          • Canuck
            Tech Specialist
            • 1713
            Loose on both RIPs...wow...as long as it works now
