Hai, i got is ir2270 showing E-733-001 problem.But i find out that under service mode<option<body<CONFIG< JP. .00.00
I change the country code to<SE< and press OK button. One after i press the OK button ,display all jam and i off and on the copier .The copier still cannot start up.I check againt the country code still go back to <JP< .Can anyone help me on this problem.Thank you.
