Machine has a B1 controller. Uninstalled all the B1 hardware but have not changed anything in service mode.
I have installed another Main Con 2 and now am stuck on a E733. I have no power at the reader and no power at J129 on the DC controller. Power Supply/ Relay board has been changed. No power coming out of the relay board to the DC controller. Put in a second Power supply and got the same result. No power to DC Cont and No power to the reader. I seem to have power everywhere else. No feeder shows up in service mode with Japanese details for items in service mode. Experience with changing main cont 2 top right dim and Controller has solved a E732-001 in the past. Relay boards have also solved this error.
I am going to try some diff dims on the Main Con 2 next because they are not original factory parts. Also Riser PCB. I put this here to consider all possibility's before a Main Con 1.
All fuses are good and booting up with the drum driver disconnected didn't help. No blown fuses on drum driver or anywhere else can be found.
