Canon IR 3300 photocopier machine Jamming
  • princepriyu
    • May 2025
    [Jamming] Canon IR 3300 photocopier machine Jamming
    i am using Canon IR3300 photocopier machine very finely, it is with 4 trays
    recently i am facing a paper jam issue.
    it happens suddenly and paper jam definitely happens at the last page in the tray
    paper (Size : A4) gets jammed right at the paper pickup point. inside the tray it does not even peeps out at the right door.
    after printing some pages it gets jammed once prints normally and again gets jammed suddenly
    I have replace the entire paper pickup rubber set but my problem still remains unsolved
    please anyone can suggest me what should i check to clear it
    thanks
  • Brian8506
    • 1658
    • princepriyu
      Re: Canon IR 3300 photocopier machine Jamming
      • Brian8506
        • 1658
        They come up as invalid links
        • princepriyu
            Originally posted by princepriyu
            [ATTACH=CONFIG]43630[/ATTACH][ATTACH=CONFIG]43631[/ATTACH]
            invalid links
            • Brian8506
              • 1658
              • techandtrader
                • Jun 2016
                • 318
                Its either poor / thin paper or aftermarket rollers. Genuine Canon rollers are no longer available for these. Need to change rollers more often now and avoid old car stock.
                I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                • rapidocument
                  Multibrands Tech
                  • Jul 2012
                  • 381
                  If you instal
                  My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
                  • rapidocument
                    Multibrands Tech
                    • Jul 2012
                    • 381
                    If you installed a generic "rubber" it might be directioned backwards.
                    try installing it the other way. if you are a tech you'll figure it out.
                    • roho
                      • Mar 2009
                      • 844
                      Used to get a flood of 0107 jams on this puppy. Sometimes you had to add a turn to fuser outlet sensor arm return spring...............
                      • campy
                        • May 2012
                        • 315
                        Your correct, they use to get dirty and would be too slow to return to normal position.
                        • Momiowilove
                          • Sep 2019
                          • 63
                          Remove tgey pads inside the paper feed unit . Its near in the flag sensor of the feed unit
                          Sent from my RNE-L22 using Tapatalk
                          • princepriyu
                            where ??? any image for reference
