Jamcode 201&101
  • Arjundpl
    • Sep 2019
    • 2
    [Jamming] Jamcode 201&101
    Facindg a paper jam in ir3235 in fuserunit and sometime paper was delivered two bumps on paper and crushing sound while printing and jam code was 201 and some time 101
  • guitar9199
    • Sep 2016
    • 1100
    Re: Jamcode 201&101
    "01xx" jams are "Delay" jams....
    "02xx" are "Stationary" jams.
    So the 0101 and 0201 jams all point to the Cassette 1 sensor. First thing to do is check the condition of the feed/pickup/separation rollers on the first tray. If you can still see tread on the feed and separation rollers, they just may be dirty. Clean them and you should see improvement.
    If the Feed and Separation rollers are smooth, replace all of them as a set.
    Start there.... and if you're still having issues, report back in.
    • Arjundpl
      • Sep 2019
      • 2
      Re: Jamcode 201&101
      Technician come and said film sleeve was problem and Caset gears was some thing problem is that person was correct or not
      • TSS
        • Jul 2018
        • 30
        Re: Jamcode 201&101
        0101,0201 are timing jams. i think.Sounds like the fuser upper needs replacment.Replace the upper, lower roller,bearins 2 cleaning roller.
        • guitar9199
          • Sep 2016
          • 1100
          Re: Jamcode 201&101
          It's possible. Not being able to see the machine, or knowing what the counters are it makes it hard to diagnose over the internet. I always tell techs I've trained, "Start with the simple stuff first". First thing I check on a delay jam is the feed rollers. Sometimes the easiest/cheapest fix is the RIGHT one, but it's smarter than STARTING with a fusing unit, only to find your problem was feed rollers all along.
