Canon ir2545 error 248
  • mdm7266
    • Dec 2007
    • 99
    Hello. I have a problem on ir2545. I already replaced the flex cables, relay controller, main controller, dc controller and the power supply and still error 248 upon power on. The error does not clear on service mode error engine clear. Does anyone here encountered this problem. Hope someone can help. Any idea?
    Code: E248-0000
    Description:
    EEPROM error
    1.An error has occurred at power-on.
    2.An error has occurred during write operation.
    3.An error has occurred during read operation following write operation.
    Remedy:
    1.Disconnect and then connect the flexible cable(Relay PCB (PCB2)-Main Controller PCB (PCB1) 50pin). 2.Disconnect and then connect the flexible cable(CCD unit- Relay PCB (PCB2)). 3.Disconnect and then connect the power supply harness connector. 4.Replace the flexible cable. 5.Replace the CCD Unit. 6.Replace the Relay PCB (PCB2). 7.Replace the Power Supply PCB (PCB3). 8.Replace the Main Controller PCB (PCB1).
  • teckat
    • 16092
    Re: Canon ir2545 error 248
    Connections issue :-(
    Check the Reader connection
    • mdm7266
      • Dec 2007
      • 99
      Check, clean and reinstall the flex cable going to the scanner/reader assembly. Clear error solved the problem error 248.
      Thanks for the reply Teckat.
      • teckat
        • 16092
        Thanks_Pizza Man .jpgwelcome
        • mdm7266
          • Dec 2007
          • 99
          Hello teckat. Error 248 return again. This time it wont clear the error in service mode. Also tried rcon clear. Still error 248. stdr-pos NG. Do this error can be solve by reflashing? Can this be ccd reader error? I have no spare scanner assembly to try. Any other solution?
          • teckat
            • 16092
            did u put in Label Settings after RCON CLR ???
            +Perform the following in the service mode:
            SCAN > READER > FUNCTION > CCD > DF-WLVL1/2/3/4 (DF white level adjustment)
            not too many options
            what is sub code ??
            E248 0001
            EEPROM error of the CCD unit
            Description ;An error has occurred at power-on.
            Remedy
            E248 0002
            Description; An error has occurred during write operation.
            Remedy
            E248 0003
            Description; An error has occurred during read operation following write operation.
            Remedy
            • mdm7266
              • Dec 2007
              • 99
              E248 001
              All SCAN > READER> FUNCTION > CCD > DF-WLVL1/2/3/4
              NG status
              Upon engine error clearing E719 occurs. erroneous communication on new card reader. But did not replace card reader.
              • Rohimin Prawironegoro
                • Jan 2019
                • 3
                replace the flexible cable
                if you still can't
                Try replacing the CCD unit
                • mdm7266
                  • Dec 2007
                  • 99
                  if you still can't
                  Hello all, Can somebody give me thd part number of the CCD unit Only. Not the Scanner assembly. Only the CCD.
                    • Jan 2019
                    • 3
                    Cariage
                    • mdm7266
                      • Dec 2007
                      • 99
                      Cariage
                      I know the part number of the carriage assembly.
                      Its FM3-9435-000 Carriage unit
                      I would like to know if i can order the CCD unit only if it has its separate part number.
                      I dont have the carriage assembly. I'll try to order the ccd only because if its assembly it will cost more expensive.
